EasyTune install fails unable to read from .msi file from network?
Easy Tune 6 B12.1121.1 Error
Error 1316.A network error occurred while attempting to read from the file C:\Users\CONRAD~1.CON\AppData\Local\Temp\_isE926\Easy Tune 6 B11.1209.1.msi
OK
Windows 7 x64 intel - is ET6 the download corrupted?
« Last Edit: November 21, 2013, 08:10:15 pm by zaphodikus »
Re: EasyTune install fails unable to read from .msi file from network?
« Reply #1 on: November 21, 2013, 08:21:54 pm »
Completely broken for me - um, please help cannot imnstall ET6. I used to have it installed, but it got broken by the updater - I cannot install.
please help.
« Reply #2 on: November 21, 2013, 09:33:58 pm »
Frustrated a bit, used an ad-remove cleaner - rebooted re-downloaded and installer still crashes.
avitar
  • 18
« Reply #3 on: January 01, 2014, 02:32:19 pm »
Did this get fixed - I have exactly same problem - I can install old version of easytune6 from CD ok, so it is obviously a problem with new version, on win 7 64.
Any work around?
John
  • 2899
« Reply #4 on: January 01, 2014, 03:26:32 pm »
Mine didn't work either and I just tried it again it work. The thing is make sure your Chipset and Intel Management Engine Components drivers are up to date. That is the only thing that have updated from the last time I tried it.
avitar
  • 18
« Reply #5 on: January 01, 2014, 03:39:07 pm »
Can't see why drivers would impact installation - the problems we all reported were problems with the .msi installing easytune6 not of easytunes failing to work!
BTW, my mb is GA-78LMT-S2P (rev. 5.x), amd fx 4100 although don't think this is relevant - it is a problem for gigabyte to fix the installation and the way that the msi is used, not with the m/b.
John
  • 2899
« Reply #6 on: January 01, 2014, 08:12:17 pm »
I could be wrong but what I'm reading is that if you still had a early version installed it could cause the problem.
I have found this on many other forums that people are having problems.
This is what one person posted: GIGABYTE Easy tune-6 B12.1122.1 >> Please remove current / earlier version of Easy Tune-6 before installing this, otherwise Easy tune-6 will no longer function permanently!
« Last Edit: January 01, 2014, 08:14:37 pm by dmdilks »
avitar
  • 18
« Reply #7 on: January 01, 2014, 08:48:15 pm »
The version that I'd originally installed was from 2012 or so- came on the installation CD with the m/b.
I saw the note about removing old version before installing new one. I could not find a de-install, so I merely deleted the files & folders that et6 had generated. How should one de-install? Why no de instal filel?
John
  • 2899
« Reply #8 on: January 01, 2014, 10:56:36 pm »
Start / programs / Gigabyte or Control panel Programs & features. In both areas you can uninstall them.
You just can't delete folder and files. There is still stuff in the Registry. Till you get that stuff out of the registry you basically screwed sorry.
avitar
  • 18
« Reply #9 on: January 06, 2014, 04:04:39 pm »
OK, thanks, reinstalled original version, then removed it  properly as per your email, then installed new version, and it installed ok. It shows up as the latest 2013 version and appears to run ok, showing the bios settings.
However, when I run it and select the tuner tab, I get the frequency tab, but don't get the ratio and voltage tabs as shown in the help, so can't change these.
Anyone any ideas about why? GA-78LMT-S2P on win 7 64 sp1, with latest f4a bios
John
  • 2899
« Reply #10 on: January 06, 2014, 05:58:48 pm »
When you are on that tab look at the Mode under that you see three tab Quick Boost, Easy, & Advance that is what you are looking for.
avitar
  • 18
« Reply #11 on: January 06, 2014, 06:45:12 pm »
Can see mode - only 2 tabs there easy & advanced - neither has voltage changing.
John
  • 2899
« Reply #12 on: January 06, 2014, 08:00:38 pm »
On mine that is under the Advanced tab. I have Frequency, ratio, Voltage, l & Voltage ll
avitar
  • 18
« Reply #13 on: January 06, 2014, 08:35:57 pm »
thank- so it can work, on amd- any ideas re what could be wrong with mine? Things I could try?
John
  • 2899
« Reply #14 on: January 06, 2014, 08:39:11 pm »
I have a AMD board and I'll try it on mine.
