New Build
New Build
« on: February 04, 2014, 04:23:43 pm »
As I await my new gaz87x ud5h to arrive, I have concerns about installing Win7 x64.  One this board, is this a true Uefi? If so, then will it only install on HD's that are GPT, or will MBR work also? I have seen post about others having issues getting Win7 installed, is this part of their problem?
 I have not put a new system together in a couple of years so I have some catching up to do. Thanks.
GA-Z87X-UD5H V1 BIOS F9
Intel Core i7 4770K 3.5Ghz
Corsair Vengeance 4x8GB DDR3 1600Mhz
SATA: WD Raptor 500 gig (GSATAIII0) 2 WD Black FZEX 2TB(GSATAIII1,2)
Viewsonic VP2770-LED
Win 10 - all latest updates
EVGA GeForce GTX 750ti
EVGA 850 G2 PS
Fractal Design Arc Midi R2 Case
Cryorig H5
  • 2897
Re: New Build
« Reply #1 on: February 04, 2014, 07:04:18 pm »
Read this thread it will answer what you are looking for & what shadowsports has to say.
 http://forum.giga-byte.co.uk/index.php/topic,13993.0.html
Re: New Build
« Reply #2 on: February 04, 2014, 07:29:53 pm »
Thanks, I'll note this and hopefully not encounter issues.
EVGA 850 G2 PS
Cryorig H5
