GA Z87X UD4H internet issues
« on: March 06, 2014, 11:14:13 pm »
hey i have issue with my GA-Z87X-UD4H  whenever i try to change in device manger from 100mbps Duplex to 1gbps duplex it will say cable unplugged and the light on my d-link router will go off however if i restart the computer while it booting up the light is on and it go off once i get to my desktop
its work fine on 100mbps duplex
i am using cat5e cable
any ideas what i can try to do ?
i am using windows 7 64 bit
« Last Edit: March 06, 2014, 11:15:07 pm by mich4el »
  • 3078
Re: GA Z87X UD4H internet issues
« Reply #1 on: March 11, 2014, 02:53:41 am »
Why do you want to change it? Does you internet run faster than 100 mps? It isn't going to run any faster trying to run it at 100 mps or 1 gb.
« Last Edit: March 11, 2014, 02:55:08 am by dmdilks »
