RAM not running a 1600Mhz - only 1400Mhz
snadge
  • 62
    • The Tech Forum
« on: April 24, 2014, 04:36:37 pm »
I built  PC for a friend using the Gigabyte H81M-H mobo and 4Gb 1600Mhz RAM - it defaulted to 1333hz, I was told this is normal...thing is the RAM multiplier only goes to x14 (1400Mhz) despite its saying it supports 1600Mhz out the box>?
1 x 4Gb Crucial Ballistix Sport 1600Mhz 1.5v
1 x Giagbyte H81M-H
can anyone please help? ive been told I have to mess on with the "timings" to get it working at 1600Mhz but I dont believe this to be true because in past systems ive built with 1333Mhz RAM I have simply changed the multiplier to x16 and that was that!!
something aint right here and would appreciate some help.
  • 3078
Re: RAM not running a 1600Mhz - only 1400Mhz
« Reply #1 on: April 24, 2014, 08:39:34 pm »
Did you set it to the profile? Most of the time you don't have to set timings on Intel board.
lcdlo
« Reply #2 on: April 29, 2014, 04:23:12 am »
Usually you have to set oc.profile to xmp.
« Reply #3 on: April 29, 2014, 09:53:16 am »
Mine too. I have gigabyte h81m-hd3 and my cpu ıntel haswell g3220 and my gskill 1600mhz 1.5v memories works at max 1400mhz. I reset cmos, flashed bios and after nothing changed. What is the problem?
  • 2243
« Reply #4 on: April 30, 2014, 07:09:04 am »
snadge,
Everything these guys is saying is true.  Enable X.M.P and set target to 1600mhz if available.
« Reply #5 on: April 30, 2014, 01:20:08 pm »
XMP profile set 1600mhz but bios limit max 1400 mhz. Bios limit the multiplier max 14.
