*New* i7 4790K and Gigabyte Z87X-OC vcore problem
« on: July 18, 2014, 03:14:13 am »
Hello there
So here is my story ...
I replaced i5 4670K by new i7 4790K ... i has F8 BIOS , BEFORE  i replace CPU i reset BIOS to default ....
so all those is with default F8 settings .
 then my story start  :
1st restart - BIOS detect new cpu . vcore -1,357 V
2th restart - BIOS detect new cpu . vcore -1,235 V
3th restart - BIOS detect new cpu . vcore -1,452 V
4th restart - BIOS detect new cpu . vcore -1,487 V !·!!!!!!!
at this moment , i manualy changed vcore to 1.235 V .... cba burn my new cpu ...
I just hope to you guys working on properly detect  vcore by this MB  ?
Best Regards
« Last Edit: July 18, 2014, 03:22:36 am by kiwaczek »
Harha
Re: *New* i7 4790K and Gigabyte Z87X-OC vcore problem
« Reply #1 on: August 10, 2014, 10:46:11 am »
Hey, I have the same exact problem.
If I set the core voltages to be automatically changed by MB then it sets it to >1.4v in turbo mode and >1.2v without turbo boost.
And that is really annoying, I want to have everything at auto so the cpu wont run always @ 100% clockspeed if not needed and so on, only under load. I haven't figured out a solution so I just locked the core voltage @ 1.200v with turbo boost on and now my Core i7-4790K runs @ constant 4.4GHz and 1.200v which isn't ideal... :(
Anyone knows a solution for this? Does the new beta bios work better regarding this problem?
