B85N-Phoenix can't oc G3258 ?
r2yet
« on: November 26, 2014, 12:47:21 am »
I have B85N Phoenix rev 2.0 and cant oc with EasyTune or in BIOS, there are only underclock option in EasyTune. So is it impossible to oc with B85 Phoenix ?
autotech
  • 1532
  • 35
Re: B85N-Phoenix can't oc G3258 ?
« Reply #1 on: November 26, 2014, 01:45:26 am »
Did you do a search on how to overclock that chip. Also have you turned bios to manual on voltages and speeds? I don't have this chip and maybe someone that does can come in and give you more insight.
I buy the K series chips so it makes it easy on me I did find a few good articles on overclocking that chip by searching you motherboard cpu combo.
  • 2899
« Reply #2 on: November 26, 2014, 02:25:02 am »
You might get more help in the OC part of the forum. I did some searching and I can't find nothing on that board.
« Last Edit: November 26, 2014, 02:35:01 am by dmdilks »
r2yet
« Reply #3 on: November 26, 2014, 06:37:28 am »
Thank u for reply.
I can not change Vcore and mutiplier in bios, they are all set Auto. I dont remember  that my F1 Bios is possible to oc or that was my  Asrock b85M-itx.
  • 2899
« Reply #4 on: November 26, 2014, 01:31:29 pm »
I'm can't tell you that. I have been doing this over 30 yrs. I have never OC anything. Maybe Autotech can, but I can't. On some boards the F1 key will get you into the bios. In your book or in the bios it will tell what the F keys will do.
autotech
  • 1532
  • 35
« Reply #5 on: November 27, 2014, 08:40:57 am »
Hit the delete key to enter bios change from auto to manual. That should allow you to make adjustments. hit F10 to save and exit when done.
r2yet
« Reply #6 on: November 27, 2014, 02:28:20 pm »
I mean my F1 bios version :D All options are Auto and I cant change to manual,
autotech
  • 1532
  • 35
« Reply #7 on: November 29, 2014, 12:40:52 am »
Update to bios F3 version and see if it will then let you change it.
r2yet
« Reply #8 on: November 30, 2014, 05:06:48 pm »
already F3 version but wont work :(
