Still having issues with my GA-Z87X-D3H over a year later.
« on: June 21, 2015, 10:10:42 pm »
So disappointingly I had loads of issues with my GA-Z87X-D3H used to crash, randomly lock up, couldn't use sleep as it would lose all sata drives on start up, eventually got it sorted through various bios updates, resets and randomly changing sata channels.
Last week it's started doing this stupid thing where by it boots  without my keyboard been detected. I have to turn it off, turn it on again and it boots direct to my bios with the keyboard now detected, I then have to exit the bios and it will boot up no problem.
Does it every single time, getting pretty annoying, I'm on the latest bios already.
  • 2246
Re: Still having issues with my GA-Z87X-D3H over a year later.
« Reply #1 on: June 24, 2015, 07:56:40 am »
What OS are you running?
How is your keyboard connected?
PS/2 or USB
If USB, which port are you using?
Things to look at:
BIOS settings - USB features (see page 53-54 of your manual)
*Port you have the keyboard connected to
« Last Edit: June 24, 2015, 08:06:28 am by shadowsports »
