GA-H81M-S2PV rev. 2.0 Drivers for Windows XP 32bit
drips
« on: July 18, 2015, 02:27:41 pm »
Hi, i'm looking and looking but none of that . There will be someone who knows where to find drivers for GA- H81M - S2PV rev. 2.0 but to Windows XP ?
« Last Edit: July 18, 2015, 02:29:15 pm by drips »
  • 2243
Re: GA-H81M-S2PV rev. 2.0 Drivers for Windows XP 32bit
« Reply #1 on: July 18, 2015, 02:42:45 pm »
Try google.  I found several, but have no idea as to the integrity of the downloads.  Unsupported OS = headache in long run.  Hope you have lots of asprin.  :o
drips
« Reply #2 on: July 18, 2015, 02:45:50 pm »
I have Aspirin but not have a Time :(
Google tried , unfortunately without success
« Last Edit: July 18, 2015, 02:47:49 pm by drips »
« Reply #3 on: July 18, 2015, 03:23:19 pm »
You can download a copy of the original Driver Disk for this motherboard from here: http://www.hwdrivers.com/drivers/dev_mboard/ven_Gigabyte/mod_GA-H81M-S2PV/drv_007037/
That should have your XP32 bit drivers on it.
Tiger
  • 276
  • 13
« Reply #4 on: July 18, 2015, 08:10:18 pm »
Specifications for GA-H81M-S2PV rev. 2.0 read:
Operating System: 1.Support for Windows 8.1/8/7
Intel ended support for Windows XP and Vista with the Series 7 chipset. As a result, there are no drivers for Windows XP and Series 8 chipset motherboards such as the Intel H81 Express Chipset GA-H81M-S2PV rev. 2.0.
1) GA-Z97X-Gaming 7, G3258,
2) GA-990FXA-UD3 Rev. 1.1, FX-8350
3) GA-AM1M-S2P, Sempron 3850 Kabini
