Login
Register
Close
Login
Remember me
Toggle navigation
Home
Help
Login
Register
Questions about GIGABYTE products
Motherboards with AMD processors
GA-990FXA-UD3 (rev. 1.0) and Windows 10 drivers
« previous
next »
Print
Pages: [
1
Go Down
vothros
21
0
on:
July 31, 2015, 12:28:51 pm »
Hello, I have the motherboard GA-990FXA-UD3 (rev. 1.0) and I don't see drivers for Windows 10 64bit.
I mean, it has only for Audio and Lan.
What about Chipset, USB 3.0 etc etc
Will they come out?
Looking forward for a reply.
Thank you.
Logged
2248
67
Xbox One, Drives STI, Use QVL RAM For Best Results
Re: GA-990FXA-UD3 (rev. 1.0) and Windows 10 drivers
Reply #1 on:
July 31, 2015, 02:51:37 pm »
http://support.amd.com/en-us/download/chipset?os=Windows%2010%20-%2064
Logged
Z390 AORUS PRO (F10)
\850w, 9900K, 32GB GSkill TriZ RGB - 16-18-18-38, RTX 3080Ti FTW3 Ultra, 960 Pro_m.2, W11
Z370-HD3P (F5)
\750w, 8350K, 8GB LPX 3200 - 16-18-18-38, GTX 970 FTW SC, Intel SSD, 2TB RAID1, W11
Z97X-UD5H
\850w, 4790K, 32GB Vengeance, RTX 2080 FTW
vothros
21
0
Reply #2 on:
July 31, 2015, 03:23:42 pm »
Quote from: shadowsports on July 31, 2015, 02:51:37 pm
oh thanks!
Logged
3085
43
"If it isn't broke don't fix it"
Reply #3 on:
August 03, 2015, 03:01:15 pm »
The thing is when windows loads and it installs all the drivers. If I look in device manager and everything is load. I don't waste my time looking to upgrade any drivers other then maybe video driver.
I have been doing this for 30 yrs. Yes if you run into a problem with something on the MB. Then yes you look at the driver for that item. But you really don't need the most and newest driver or bios.
If things are working leave things well enough a lone. All my drivers on my computer are over a year old. Plus some of them were loaded by windows.
Logged
Print
Pages: [
1
Go Up
« previous
next »
