motherboards available in the UK
« on: November 16, 2015, 09:49:03 am »
looking to replace an ageing 880 motherboard , want to stay Micro-atx  but what is the best board available in the Uk
could anyone recommend a UK supplier of gigabyte boards , I am tired of constantly going back and forth the gigabyte site , only to find boards that are either discontinued or simply not available .
Matx am3+ would do for now ,but I have not kept in touch with progress the past year or two ,so if anyone could suggest a better newer format I am happy to look . the 880 series seem to have been long discontinued , so what did they replace them with ????
  • 3078
Re: motherboards available in the UK
« Reply #1 on: November 16, 2015, 01:53:00 pm »
I'm here in the USA, but I would go with a FX2+ board. It supports 3.0 video cards. They might be easier to find then the AM3+ boards.  https://www.overclockers.co.uk/pc-components/motherboards/amd
