GA-Z170X-Gaming 7 cant change Bios settings
« on: April 26, 2016, 02:48:23 pm »
 I cant change many bios setting like cpu vcore or cpu multiplier and a host of others. They just say auto and when I hit enter to change the value nothing happens. My cpu is 6600k.
  • 2243
Re: GA-Z170X-Gaming 7 cant change Bios settings
« Reply #1 on: April 26, 2016, 11:09:18 pm »
Unlocked CPU.  What brand of RAM and speed are you using?  Are you using an XMP profile?  Have you tried clearing the CMOS, or battery pull and setting up the BIOS again?
« Reply #2 on: April 27, 2016, 02:47:52 pm »
 My Ram is 16gb G.Skill Trident-Z DDR4-3600 (PC4-28800) CL17-18-18-38 1.35 Volt. Not using xmp. I cleared CMOS and still having the same issue.
« Reply #3 on: April 27, 2016, 04:50:46 pm »
Hello,
Highlight the field, don't press enter.
Instead type the value you would like then press enter.
So CPU ratio for example,
highlight field
type: 35
Press enter.
Should work like that?
My PC is evolving
« Reply #4 on: April 27, 2016, 05:22:42 pm »
Hello,
highlight field
type: 35
Press enter.
 Ha, it worked! Now I feel stupid. Thank you sir. You are both a gentleman and a scholar.
  • 2243
« Reply #5 on: April 29, 2016, 02:04:12 pm »
Na, give credit to Electro for that one... ;)
