Will Gigabyte X99P-SLI ever support Corsair Vengeance LPX DDR4 3333 ?
risey
  • 15
    • Phat Monkey
XMP profile simply does not work with the 4x16G CorsVengLPX DDR4 3333 bios F21...
Gee wiz :)
Windows 10 64bit, Gigabyte X99P-SLI, Intel Core i7 5960X @ 3.00GHz (medium OC), 2 MSI GTX 1080X, ASUS VG278HR, ACER Predator 35inch 144hz, Corsair Vengeance LPX 64GB DDR4 - Memory Kit 4x16GB, Corsair H115i AIO Hydro, Corsair 900D.
  • 3082
On they list you memory doesn't show up. They only show 4 & 8gb sticks for support no 16gb sticks.
Qualified Vendors List (QVL), Model Name: GA-X99P-SLI
DDR4 3333
G.SKILL  4GB F4-3333C16Q-16GRKD SS Hynix 16-16-16-36 1.35v v v v 2133
Kingston 4GB    HX433C17PBK4/16    SS          17-17-17-43 1.35v v v v 2133
risey
  • 15
    • Phat Monkey
I see, but there beta bios which they now have removed did mention it added more support for DDR4 set ups. Support suggested I try it but the bios did not work for me, PC kept rebooting didn't even give me a chance to enable XMP lol. Had to go back to F21. There is a new BETA bios on there now but no mention of DDR4 support, I dare not try it, probably brick my mb.
« Last Edit: June 06, 2016, 10:53:34 am by risey »
  • 3082
I run a Ga-x99-UD4 board and my board had a update to run 16gb sticks.
Beta BIOS - F13b   8.17 MB   2015/07/03   Asia China America Europe Europe(Russia) : FTP / Http
Support 16GB DDR4 memory module
Improve HDD compatibility
If the updates are not saying that then you can't run 16gb sticks. If you are going to return the memory. I would just get 8 - 8gb sticks of 2133. Yes in theory it says it should run at 3333 but it really still runs at 2133. Plus 2133 vs 3333 you not really see a speed boost.
risey
  • 15
    • Phat Monkey
I am happy as it is right now 64gig of Ram is more than enough, it is just a little disappointing that the xmp does not work for me. I switched from Asus to Gigabyte few years ago as the maximus V was having issues with SLI, after numerous unofficial bios updates at ROG that did not work I gave up and switched to the Gigabyte g1 sniper 5, never had an issue and it was the main factor I invested in the X99 SLI.
I would be interested to find out how the Thunderbolt 3 works when I connect an adapter for thunderbolt 2 devices, as a music producer I want to invest in the new thunderbolt sound cards but something is telling me..... it will all go south on this motherboard, I may be wrong :)
I already had a problem with Firewire, I tried 3 different PCI cards and although device manager claimed the device was working fine it would not communicate with my external sound card MBOX 3 PRO, did not have this problem on the Sniper motherboard. I think I may have made the wrong investment but a motherboard is simple to switch out if need be...
