X99-ud4 RAID question
« on: October 13, 2016, 03:26:47 am »
When using the intel RAID 5 can I raid 3 drives and still use the other 3 Sata ports with individual drives or if I set it to raid do I lose all 6 Sata ports to the raid function regardless of how many drives I raid?
  • 2884
Re: X99-ud4 RAID question
« Reply #1 on: October 13, 2016, 01:08:10 pm »
Yes you can it will be all Raid too. Raid and AHCI are about the same. I have my 2 SSD in a array and have four other single drives running at the same time. As far as I know you can run Raid 0 & Raid 3 at the same time too.
« Last Edit: October 13, 2016, 01:09:03 pm by dmdilks »
« Reply #2 on: October 13, 2016, 01:13:40 pm »
Thank you!
