P55 v5 FPS drops (stops charging randomly)
EdwinP
« on: October 27, 2016, 09:33:59 am »
As there's pretty much no support from the official gigabyte support team and the guy who should be providing technical support in Melbourne is not answering the phone, I guess that's my last resort...
Bought Gigabyte P55 v5 three months ago (GTX 970M), ever since I'm having these odd issues with FPS dropping when GPU is under performance, the fps drops even under moderate performance (like Dota2).
I recorded what happens when I run a benchmark on ultra (same happens if I run it on basic settings). So basically my laptop switches the power plan mode randomly as it shows that battery isn't being charged although it's plugged in. If I remove the charger and set it on high performance power plan it doesn't occur, yet the FPS are lower compared to laptop plugged in.
Please see the link below for video:
https://goo.gl/photos/iMySB5kE7yDRvDeK8
This issue is driving me nuts as the laptop has fairly good specs and is pretty new... The fact that support is non existent doesn't help :/
Please guys, any suggestions are appreciated, is it a charger issue, video card or software?
Full specs below:
System Information
Time of this report: 10/27/2016, 19:21:05
       Machine name: EDVINAS
   Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_ltsb.160930-0600)
           Language: English (Regional Setting: English)
System Manufacturer: GIGABYTE
       System Model: P55V4
               BIOS: FB0B
          Processor: Intel(R) Core(TM) i7-5700HQ CPU @ 2.70GHz (8 CPUs), ~2.7GHz
             Memory: 16384MB RAM
Available OS Memory: 16298MB RAM
          Page File: 17874MB used, 7309MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: 120 DPI (125 percent)
 System DPI Setting: 120 DPI (125 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.03.9600.17415 64bit Unicode
Display Devices
          Card name: Intel(R) HD Graphics 5600
       Manufacturer: Intel Corporation
          Chip type: Intel(R) HD Graphics Family
           DAC type: Internal
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_8086&DEV_1612&SUBSYS_15551458&REV_0A
     Display Memory: 3968 MB
   Dedicated Memory: 128 MB
      Shared Memory: 3840 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: unknown
         Monitor Id: LGD042C
        Native Mode: 1920 x 1080(p) (60.020Hz)
        Output Type: Internal
        Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 20.19.0015.4501 (English)
     Driver Version: 20.19.15.4501
        DDI Version: 11.1
     Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 1.3
Graphics Preemption: Triangle
 Compute Preemption: Thread group
           Miracast: Supported
Hybrid Graphics GPU: Integrated
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 8/19/2016 00:14:44, 39512776 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B78E66-5552-11CF-7D66-5A35B6C2D935}
          Vendor ID: 0x8086
          Device ID: 0x1612
          SubSys ID: 0x15551458
        Revision ID: 0x000A
 Driver Strong Name: oem5.inf:5f63e53472aaf42d:iBDWM_w81:20.19.15.4501:pci\ven_8086&dev_1612
     Rank Of Driver: 00DA2001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT
   Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
          Card name: NVIDIA GeForce GTX 970M
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 970M
           DAC type: Integrated RAMDAC
        Device Type: Render-Only Device
         Device Key: Enum\PCI\VEN_10DE&DEV_13D8&SUBSYS_15551458&REV_A1
     Display Memory: 11109 MB
   Dedicated Memory: 2960 MB
      Shared Memory: 8149 MB
       Current Mode: n/a
        Driver Name: nvd3dumx,nvwgf2umx,nvwgf2umx,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 21.21.0013.7563 (English)
     Driver Version: 21.21.13.7563
        DDI Version: 11.1
Graphics Preemption: DMA
 Compute Preemption: DMA
           Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Discrete
   Driver Date/Size: 10/22/2016 18:20:53, 17426520 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: n/a
          Vendor ID: 0x10DE
          Device ID: 0x13D8
        Revision ID: 0x00A1
 Driver Strong Name: oem31.inf:0f066de3ff697fd5:Section057:21.21.13.7563:pci\ven_10de&dev_13d8&subsys_15551458
     Rank Of Driver: 00DA0001
        Video Accel: n/a
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeVC1_VLD  DXVA2_ModeH264_VLD_NoFGT
      Deinterlace Caps: n/a
       D3D9 Overlay: n/a
            DXVA-HD: n/a
         D3D Status: Enabled
         AGP Status: Enabled
« Last Edit: October 27, 2016, 09:36:41 am by EdwinP »
