Problem with Gigabyte z270-HD3
« on: March 01, 2017, 07:26:27 pm »
Hey I just bought  this motherboard and a i5 7600K and a new SSD. When I finished building the PC I installed windows at this point everything was OK. The problem began when I finished installing the drivers and I noticed that the ethernet LAN driver of Intel doesn't work for me. The installation process say "tall drivers. no intel(r) adapters are present in this computer"
I already tried installing windows again but nothing seems to solve this problem
wh173
  • 29
Re: Problem with Gigabyte z270-HD3
« Reply #1 on: March 01, 2017, 10:50:27 pm »
Either a faulty motherboard that you need to replace, or a broken bios. I would start a ticket to replace the board.
Sandokan
  • 14
« Reply #2 on: March 03, 2017, 02:09:54 pm »
Check if LAN it is enabled or disabled into the BIOS.
walk3r
  • 17
« Reply #3 on: March 09, 2017, 01:42:07 pm »
You may check the Intel Network Adapter is listed in Windows Device Manager. If so is there a yellow "!" next to it?
Please tried the Intel LAN driver from Gigabyte website.
http://www.gigabyte.com/Motherboard/GA-Z270-HD3-rev-10#support-dl
