GA-H110M-S2 + F20 bios?
« on: March 07, 2017, 06:36:14 pm »
I have a GA-H110M-S2 with last bios f20 + i7 7100 + 8gb Corsair Vengeance and everything works ok if I don't plug my 7600 gt on it.
If i use the 7600gt the system doesn't boot and I receive a message telling  that didn't found any boot HD installed, BUT if I remove the videocard the system runs ok.
Tested the videocard in other PCs and it works, but not in my GA-H110M-S2 with f20 bios.
Buying a gtx 1060 but I'm afraid it wil not work too.
Someone have any tip to solve this problem??
Thanks!!
  • 2246
Re: GA-H110M-S2 + F20 bios?
« Reply #1 on: March 08, 2017, 03:33:59 am »
Follow the steps in this post and downgrade to F4.
http://forum.giga-byte.co.uk/index.php?topic=17957.0
