Gigabyte GA P35-DS4 (rev2.0) can't resume by OS standby mode
« on: March 17, 2017, 06:27:41 pm »
Hello everyone,
After wrote unsuccesfully to Gigabyte support, I'm trying writing here hoping to found someone who had my same problem and who fixed the issue succesfully.
recently I received an used GA P35-DS4 rev2.0 as gift and I've built a PC with the following components:
Mainboard: GA P35 DS4 (bios F14, the latest one released)
cpu: Intel Q6700
ram: 4x2GB samsung PC2 6400 (M378T5663QZ3)
dvd rw: ASUS DRW-24D5MT (sata)
HDD: Kingston SSDNOW sv300s37a120g (AHCI mode)
PSU: RASURBO 560W
GPU: nvidia geforce GT610
O.S.: Windows 7 Professional x64 sp1
Once installed and activated the OS everything seemed to run alright. But few days ago I left the PC turned on while talking at the telephone and 10/15 minutes after it was gone in suspend mode.
When I came back for working with the PC I pressedthe mouse button and the PC tryed to resume form suspend mode, but unsuccesfully... infact the PC started run in a strange boot-loop: it turned on for about one second (the fans also turned on again, everything seem start running again...) then it shut down automatically, some seconds after it turned on again automatically for about another second then shut down again, some seconds after it turned on again for another second then shut down again....until I disconnect the power cable from the PC.
Once reconnected the power cable and pushed the pc start button, the PC turn on regularly resuming the previous windows session (incredible!!!!).
Really I couldn't understand what's wrong....there's ome driver to install or update?there some setting to change into the BIOS? I don't know.
Gigabyte support haven't been able to tell me what's causing the issue nor how to fix it, but sure I can't believe that that's the right way for resuming a suspended windows session without damaging the mainboard.
during the past days I searched for the fix on the web without find it.
Now I hope to find here someone who know how to fix the problem and who will help me.
  • 954
  • 29
  • Rev 1.1, BIOS F8
Re: Gigabyte GA P35-DS4 (rev2.0) can't resume by OS standby mode
« Reply #1 on: March 18, 2017, 02:39:21 am »
Sorry for the issue you are experiencing.
10 yr old hardware.  You may have inherited someone else's problem.  Issue could be related to drivers, a component or some level of hardware failure.  Ensure the RAM you are using is on the QVL for the board.  PSU Brand sounds questionable.  Kingston v300 series drives..  Kingston was found guilty of using lower quality components in their v300 series drives.  The ones they used/supplied from benchmarking differed from what they sold to the public.  Big scandal.
https://www.extremetech.com/extreme/184253-ssd-shadiness-kingston-and-pny-caught-bait-and-switching-cheaper-components-after-good-reviews
http://www.anandtech.com/show/7763/an-update-to-kingston-ssdnow-v300-a-switch-to-slower-micron-nand
BIOS F13 or > address' Resume from S3 fail
There's no magic fix for this behavior.
-Review the Event Viewer
-Strip the system down a see if one or more installed devices is causing an issue with resume
-Test the PSU
-Test your memory
-Test with another CPU
-Test with another OS
And maybe some good luck.
P8Z68 Deluxe Gen3\TX850, 2600k, 16GB, GTX660 FTW SC Sig2, Force III's RAID0, Seagate 1TB , W10 Pro, Corsair 230T
Nexus 6P Nougat
  • 2884
« Reply #2 on: March 19, 2017, 11:34:16 pm »
Ok I don't know if this is it but I have Asus X99 board and had it in the back room for 6 months. The thing ran great no matter what I tried on it. One day I decided to upgrade the video card to RX-470 8gb card.
From that point I could never get it to come out of sleep mode. Till this day even with new drivers same thing. Put the other card back everything is fine. So it might not be the board. It could be almost any thing.
