Aorus gaming 5 x370 memory speed
fxv300
  • 40
    • fxv300
« on: April 15, 2017, 05:49:01 pm »
Anyone has memory running at 3200 Aorus gaming 5 x370 ?
I can only get 2633
Auros Gaming 5
RyZen 1700x
32G DDR4 3200 CMK16GX4M2B3200C16
Silent Loop 280mm Liquid Cooler
Corsair 330R case
850watt PSU
  • 2246
Re: Aorus gaming 5 x370 memory speed
« Reply #1 on: April 15, 2017, 06:35:36 pm »
Support for DDR4 3200(O.C.)/2933(O.C.)/2667*/2400/2133 MHz memory modules
 * Support for higher than DDR4 2667 MHz may vary by CPU.
The 1700x does support higher speed memory, but you may have to OC the CPU a little to get above 2633Mhz with your memory (currently).  A later BIOS rev may address this.
Looks like your memory can handle it though.
