GA-Z68X-UD3P-B3 + 2500k = 5.0 GHz so far
  • 5718
  • 516
« on: January 20, 2012, 04:01:44 pm »
Just thought I would post a little image for your perusal of my current set-up with the Intel i5 2500k running at 4.8GHz.
I'm sure I can clock this little baby a bit higher than this but I am going to have to leave it for a little while before doing so.
For those who are interested, my current settings are:
CPU Vcore  = 1.375V
Multi-Steps LLC = Level 6
BIOS Version = F8d
CPU Enhanced Halt (C1E) = Disabled
C3/C6 State Support = Disabled
CPU Thermal Monitor = Disabled
CPU EIST Function = Disabled
All other BIOS settings under the MIT Section are set to AUTO or Default except for the RAM which I have set to 1600MHz
Max Temp with my Noctua NH-D14 is 64C
« Last Edit: February 23, 2012, 02:37:07 pm by absic »
Aussie Allan
  • 1969
  • 141
Re: GA-Z68X-UD3P-B3 + 2500k = 4.8GHz so far
« Reply #1 on: January 20, 2012, 04:41:42 pm »
   Cooking with Intel gas now matie ..... and you've got the clocking trick down pat ...... turn off everything except the power :D
  So when does the policy start ? .... I'm going to be watching this space for when it does ..... you can also use the egg trick.....crack one over the CPU cooler ...... if it starts turning white...... back it off 10 Mhz.... :D :D :D :D
  Seriously Absic....great result mate for someone so new to Intel  ;)
  Aussie Allan
i7-950 @4.1GHz
GA-X58A-UD3R
24GB Muskin  1600Mhz 7-9-7-24
 GTX-480 GT-EK block@940
Mips Tri-block
Mosfets,mod enzo WMST-73 & 78
Lange DDC elite pump
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
4x500- raid0-Storage
OCZ Revo Drive X2
  • 5718
  • 516
« Reply #2 on: January 20, 2012, 04:53:16 pm »
29 days before the insurance kicks in.  :'(
I have been playing around with O/C'ing for a little while now but have struggled to get past 4.5GHz until today probably the latest BIOS has helped.
In my earlier attempts I did get to 5.0GHz but, for some reason, after running a stability test for over an hour without issue the PC on next BOOT decided it didn't like my settings and after resetting itself to defaults it wouldn't let me run above the 4.5GHz mark.
There is still some more headroom with the set-up and I would like to see if I can get a 2.0GHz (or higher) O/C from the system without resorting to water cooling everything.  :P
Aussie Allan
  • 1969
  • 141
« Reply #3 on: January 20, 2012, 04:55:14 pm »
  What was the temp and Vcore at 5 Ghz ?......AA
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
  • 5718
  • 516
« Reply #4 on: January 20, 2012, 04:59:14 pm »
That depends on which software you take as being accurate.
HW Monitor showed it as 72-75C
TouchBIOS showed it as being 10C lower
Aussie Allan
  • 1969
  • 141
« Reply #5 on: January 20, 2012, 05:05:00 pm »
  and the Volts AA
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
  • 5718
  • 516
« Reply #6 on: January 20, 2012, 05:43:32 pm »
1.4V LLC set at 6
Aussie Allan
  • 1969
  • 141
« Reply #7 on: January 20, 2012, 07:06:34 pm »
   So you DO have a big set to go with your Hero Member ...... can't wait to see where you go with a policy over your head.... :D
  AA
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
  • 5718
  • 516
« Reply #8 on: January 21, 2012, 10:49:54 am »
Although the Noctua is a very impressive cooler it is beginning to be pushed to its limits. I may be able to improve things temperature wise once I do some fine tuning with the Voltage and other settings but I'm really not sure how much higher I will be able to go with my current set-up.
Oh well, I've switched to Intel, so now, I may have to also switch to Water Cooling!  :D
Aussie Allan
  • 1969
  • 141
« Reply #9 on: January 21, 2012, 10:56:03 am »
   Yup! ..... Once we have the right equipment ..... first we walk ..... then we fly .... who wants to run anyway ;D
  Thermal goop can help .... but not as much as water!...... now goop and water ;)
  Aussie Allan
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
  • 18413
  • 413
« Reply #10 on: January 21, 2012, 02:21:37 pm »
I haven't applied for one of these policies yet but the do seem to be a brilliant idea if you plan to hit the OC hard. Did you have to fill in a form with all the CPUs details on it when you purchased it ?
Your overclock seems to be going very well absic. Shame about the 5Ghz fail on the next boot wasn't it. I reckon that was just down to a poorly written BIOS.
  • 5718
  • 516
« Reply #11 on: January 21, 2012, 02:38:46 pm »
The 5.0GHz issue was with an earlier BIOS (F8c) but now running latest (F8d) and that seems better. I did have a couple of minor issues with teh system going through the reboot cycle mentioned in other posts but that only happened a couple of time and since getting to 4.8GHz it hasn't happened again.
When you take out the Intel Protection Plan you do not need any specific details about the processor apart from the model type. It has to be a retail version but they do not ask for serial numbers or anything like that. You need to register your details prior to taking the Protection Plan out and you have to pay for it using PayPal but, apart from that, it is really easy to do. If you are not from the UK or USA remember to double check that your country is covered by Intel as it seems as if, not all are yet. And if you're reading this but are not sure what we are talking about, check here: http://forum.giga-byte.co.uk/index.php/topic,8029.0.html
« Last Edit: April 01, 2012, 12:00:55 pm by absic »
  • 18413
  • 413
« Reply #12 on: January 21, 2012, 03:44:27 pm »
Hi absic,
Likewise I have just enrolled on the plan. It is brilliant for the price. 8)
  • 5718
  • 516
« Reply #13 on: January 21, 2012, 04:00:21 pm »
Well, it definitely give a little more confidence when it comes to pushing the CPU and, if the worst does happen, at least you know it isn't going to cause a hole in your pocket to replace it.
Rolo42
  • 260
  • DON'T PANIC!
« Reply #14 on: January 25, 2012, 04:54:07 am »
Did you have to disable these to get to 4.8?
Gigabyte Z68XP-UD4, i5-2500K 4.2GHz, Zalman 9900MAX, Mushkin 8GB DDR3-2133, Gigabyte GTX580@850, Crucial m4 128GB SSD, WD 2TB FAEX, Seagate 2TB LP/500GB 7200.10, Enermax Galaxy Evo 1250W, APC RS1500, Antec 1200, Ubuntu 11.10, Win7x64 Pro, Firefox, N360
