79248 Posts in 10440 Topics by 18399 Members
Latest Member: intek
banner
Official GIGABYTE Forum  |  Questions about GIGABYTE products  |  Thermal cooling solution & chassis  |  CPU temp on Athlon II X4 645 reassurance « previous next »
Pages: [1] 2   Go Down
Author Topic: CPU temp on Athlon II X4 645 reassurance  (Read 2008 times)
Scuttle
Newbie
Offline Offline
Scotland Scotland
« on: January 30, 2012, 08:47:58 am »
This is my first build and I could do with some reassurance please.
At idle, system health check in the BIOS gives the CPU at 24deg.C and sys at 32deg.C. for the following (no overclocking)
Athlon II X4 645 3.1
GA-870A-USB3
Crucial Ballistix Sport 2x2GB DDR3 1600Mhz CL10 Unbuffered (running at 1300)
XFX ATI Radeon 6450 HD 625MHz 1GB passive
Be Quiet E9 StraightPower 400W
Thermalright Ultra-120 eXtreme Rev.C with 1 Scythe Slip Stream 120mm PWM at 700RPM
Samsung HD322GJ Spinpoint F4 320GB
CoolerMaster CM690 II - 2 standard case fans, in 1100RPM out 700 RPM
Do these temps appear right?
Where is the sys temp measured?
What is the best software to check the individual cores and northbridge?
I tried Everest which showed the cores at 11deg.C and the CPU at 22deg.C. However the installation was interrupted as it was missing the digital signature. How is the CPU temp measured compared to the core temps?
Any advice/help would be appreciated.
Logged
AMD Athlon II X4 645, 3.1GHz, GA-870A-USB3 Rev 3.1, Crucial Ballistix Sport 4GB (2x2GB) DDR3 1600Mhz , XFX  6450 HD 625MHz 1GB Passive, BeQuiet E9 400W, Coolermaster 690 II Lite, thermalright-ultra-120-extreme-rev C with Sycthe SY1225SL12LM-P,  320GB Samsung Spinpoint F4, LiteOn IHAS224-19 SATA
Ben
Full Member
Offline Offline
Australia Australia
« Reply #1 on: January 30, 2012, 09:04:54 am »
Hi, Scuttle.
Temps seem okay way lower than mine.
I use 'Hardware Monitor' & 'Core Temp' to check my temps. listed below are some links you can try.
http://www.alcpu.com/CoreTemp/
http://www.cpuid.com/softwares/hwmonitor.html
Hope they help.
I am sure others on the forum will fill in any missing parts.
Ben.
Logged
Gigabyte GA-Z68X-UD3R-B3
i7 2600 (4.00GHZ)
Ripjaws X 2@8GB XL (1.7V)
Kingston Blu Hyper 2@2GB (1.7V)
Corsair TX 650
HD 6870 1gb
blu ray + dvd
1T wd hdd
500gb WD hdd
Gigabyte Armor+MX case
Noctua air cooling (4 fans)
AOC 27'
Win 8 pro Full
Scuttle
Newbie
Offline Offline
Scotland Scotland
« Reply #2 on: January 30, 2012, 09:25:15 am »
Thanks Ben
Just tried Core Temp. The cores are running at  8deg.C
Easytune  has my CPU at 21deg.C / fan 800RPM and sys 32deg.C / sys fan 1 600RPM. No mention of sys fan 2 though.
Logged
Aussie Allan
Hero Member
Offline Offline
United Kingdom United Kingdom
A yoyo uses all three fundermental laws of phisics
« Reply #3 on: January 30, 2012, 10:27:44 am »
  Those temps are very low ... Scotsman Huh! ..... open the window and bring your poor PC inside the house  Cheesy
  Your Health page in BIOS generally give Accurate readings.....but these will always show only idle loads ....... good for a cross reference though
  Aussie Allan
Logged
i7-950 @4.1GHz
GA-X58A-UD3R
24GB Muskin  1600Mhz 7-9-7-24
 GTX-480 GT-EK block@940
Mips Tri-block
Mosfets,mod enzo WMST-73 & 78
Lange DDC elite pump
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
4x500- raid0-Storage
OCZ Revo Drive X2
Scuttle
Newbie
Offline Offline
Scotland Scotland
« Reply #4 on: January 30, 2012, 02:44:26 pm »
I'll just leave it outside thanks, saves on electricity trying to keep it cool Cheesy
So what about the sys temp, is that very low too or could it get better?
Logged
Aussie Allan
Hero Member
Offline Offline
« Reply #5 on: January 30, 2012, 02:53:20 pm »
  If you move another 1000miles north it should improve  Grin ..... :Sys temp" ..... to be honest it too is very good ..... if you wanted to experiment, you could add or change a supply or exhaust fan for a higher rated one ....... the fans are rated in CFM...(cubic feet per min) and DBA (how loud) .....If you  pay a little more ....you can find a fan with a higher CFM and still hold the DBA number ...... last thing you want is a hovercraft Grin
  Aussie Allan
Logged
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
Scuttle
Newbie
Offline Offline
Scotland Scotland
« Reply #6 on: January 30, 2012, 03:44:19 pm »
Nah, my bees wouldn't survive that far north.
Initially I hadn't given noise a great deal of thought, wish I had now I've caught the bug. I want to put in a Sythe Kaze Master along with some Fractal Design FD 140s 9dB(A) at full whack. Unfortunately I already had already bought the case which leaks noise Sad But the rest of the system is reasonable. The sys fan 2 is annoying though as easytune hasn't recognised it So it's running at about 1100RPM. I've tried changing the fan, disconecting and reconnecting all the fans, reloading/upgrading easytune but it just doesn't appear.
Logged
Aussie Allan
Hero Member
Offline Offline
« Reply #7 on: January 30, 2012, 03:49:45 pm »
  With those temps you have already ....... the only way to improve is to move to water.
  Putting the garden hose in the box is not an option Wink
  Aussie Allan
Logged
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
Gold Helper
Hero Member
Offline Offline
10typesofpeopleoneswhoknow binaryandoneswhodont
WWW
« Reply #8 on: January 30, 2012, 04:49:45 pm »
It is probably due to the fact that SYSFAN_2 isn't the same as the other fan headers on the motherboard and only works at half the speed of the rest.
The Fractal Design FD140s are very nice fans and very quiet too.
Logged
Scuttle
Newbie
Offline Offline
Scotland Scotland
« Reply #9 on: January 30, 2012, 09:00:19 pm »
Sounds like the best way to takle case fans is to find some nice quiet ones like the Fractal Design FD140s an let them run at full speed or through a fan controller.
One final question then. On CPUID Hardware Monitor,
TMPIN0 35deg.C  System
TMPIN1 24deg.C  Huh
TMPIN2 21deg.C  CPU
What is TMPIN1 likely to be?
Logged
Aussie Allan
Hero Member
Offline Offline
« Reply #10 on: January 30, 2012, 09:15:02 pm »
  Northbridge  Wink
  Aussie Allan
Logged
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
Scuttle
Newbie
Offline Offline
Scotland Scotland
« Reply #11 on: January 30, 2012, 09:27:45 pm »
Ok, I lied. Two final final questions.
Any idea where the system temp is measured and how does that seam for a northbridge temp at idle?
Logged
Aussie Allan
Hero Member
Offline Offline
« Reply #12 on: January 30, 2012, 09:47:41 pm »
  Typical Scotsman ... Smiley .... Thats what my Grandad Archie Snowden said on his death bed, aged 97 ...... over 5 day!  Cheesy
  TMPIN1 Temp is more than fine ...... From memory I think the temp censor is embedded in the chip (or it'll be underneath it) .... shall we pull it apart and see! ..... any questions you have....where here to help.
  Aussie Allan
Logged
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
Scuttle
Newbie
Offline Offline
Scotland Scotland
« Reply #13 on: January 30, 2012, 10:45:48 pm »
Many thanks for all the replies, it’s reassuring to know that nothing's burning.
All I need to do now is convince the wife that the benifits of SSDs are worth the cash.
Logged
Aussie Allan
Hero Member
Offline Offline
« Reply #14 on: January 30, 2012, 10:53:33 pm »
  Actually!....I noticed the other day that The OCZ 120G Vertex3 were on special for £114 inc and delivered
                          You could tell her every third one comes with a Diamond ring  Grin
  Aussie Allan
Logged
i7-950 @4.1GHz
GA-X58A-UD3R
Mips Tri-block
G changer360 Rad
Phobya 450 balancer
W7-64
Zigor 2000 UPS
1x500GB for clone
2x1TB backup
OCZ Revo Drive X2
Pages: [1] 2
    Jump to:
