79248 Posts in 10440 Topics by 18399 Members
Latest Member: intek
banner
Official GIGABYTE Forum  |  Questions about GIGABYTE products  |  Motherboards with AMD processors  |  lost mounting screws for 890gpa cpu mounting bracket-need thread size to replace « previous next »
Pages: [1]   Go Down
Author Topic: lost mounting screws for 890gpa cpu mounting bracket-need thread size to replace  (Read 315 times)
cravinmild
Newbie
Offline Offline
« on: July 28, 2012, 03:57:29 pm »
I have a question.   I upgraded my rig and sent the old parts off to my mom to help reduce the costs of replacing her 10y old pc.   Id run a H70 which did not require the stock bracket.   Over the years id missplaced the screws to hold the front mount to the backplate and it has caused issues when she when to complete her build and could not attach the bracket as its needed to mount the new H80 she purchased to cool the cpu.
As a short term solution she has used zipstraps to attach the bracket by using the "knuckle" end as the screw head and pulled the rest of the zipstrap through the mobo and backplate.   The other end coming through the backplate has a second zipstrap slid onto it as a locker and repeated it on the remaing three corners.   It is working well for now keeping her oc 1055t (4ghz) at 20c idle and 24c load but she is hoping for a proper mounting applications and would like to buy the screws to replace the zipstraps with.
Does anyone know the thread size of the screws so she can go to Home Depot and purchase the proper screws for replacing the zipstraps with.
Thanks for the help all, hope we can figure this out soon.  Wink
Logged
autotech
Hero Member
Offline Offline
United States United States
« Reply #1 on: July 29, 2012, 12:49:25 pm »
Home depot probably wont have them try ace hardware or if you have a mom and pop computer store try them. About the only way to do it is take the computer in and let them try a couple. Otherwise email manufacture and see if they have the info you need.
Logged
GA890FXA-UD5\,Silverstone Strider 1000watt\ ,AMD Phenom 2 1090T\ ,4x4gb gskil 1600 ripjaws\,Corsair Force Series 3 CSSD-F240GB3A 240GB SATA III Internal SSD \ windows 7 ultimate 64 bit limited edition\,1 x 6970 2 gig\,Audigy 2 ZS plat. sound card,5.1 creative 550watt speakers,3 500 gig wd platters
autotech
Hero Member
Offline Offline
« Reply #2 on: August 03, 2012, 03:27:18 am »
If you havent found any yet pm me your email i have alot of spare screws i can send a few if you are in the usa i cant garantee they will work but it is a shot.
Logged
Pages: [1]
    Jump to:
