I created a bootable windows 7 installation usb disk which works fine on my other machines and boots and installs perfectly.
I cant seem to get my motherboard to boot from the usb, ive tried with fat32 and ntfs, legacy and usb is enabled in the bios.
I've tried booting from every type of usb option(USB-HDD, FDD, ZIP ect) created the usb disk in DOS,windows GUI and with third partys apps with still no luck. Have tried putting the usb in different usb slots with no success either.
I could try to update bios although i dont see why the 2009 bios couldnt boot from a USB flash drive
If anyone has any ideas would be great thanks
