GA-Z77X-UD5H Windows 8 Drivers
Nazzer
« on: December 29, 2012, 08:04:12 pm »
I recently purchased a GA-Z77X-UD5H rev.1.0 and the CD for drivers etc. that came with it is for Windows XP/7. My OS is Windows 8. I am usure exactly what I need to download and install from gigabyte support page. So far I have installed:
Creative SB X-Fi MB2 driver 1.0.0.3
Realtek Function driver for Realtek R2.70
Intel Management Engine Interface
8.1.0.1263
Intel INF installation 9.3.0.1021
Intel LAN Driver 17.4
Intel® Rapid Storage Technology 11.6
Do I need any other drivers installed? Have I made any mistakes?
Am I missing anything important?
Cheers
Nazzer
Re: GA-Z77X-UD5H Windows 8 Drivers
« Reply #1 on: December 31, 2012, 07:46:51 am »
No one have any information here?
Would really be grateful for some feedback.
Benz
  • 28
« Reply #2 on: December 31, 2012, 11:45:58 am »
Creative SB X-Fi MB2 driver - Yes
Realtek Function driver for Realtek Azalia audio chip - Yes
Intel Management Engine Interface - Yes
Intel INF installation - Yes
Intel LAN Driver - Yes
Atheros LAN driver - Yes
Intel® Rapid Storage Technology - Yes
Hot fix for IRST - Yes
Intel SATA Preinstall driver - No
Marvell Preinstall Driver - No
Marvell Storage Utility - No
Marvell SATA Controller Driver - Yes
Intel VGA Driver - If you're using your onboard graphics card - Yes, If you're not using it - No
