GA-MA770 UD3 does not detect SATA devices
Re: GA-MA770 UD3 does not detect SATA devices
« Reply #15 on: January 30, 2010, 12:22:52 pm »
Bios updated to FG.
Unused screws removed.
And..... it didn't help.
Damn it's my first GB mobo (previously i had Foxconn/Asus) but i didn't realize i would have such a wierd problem with it.
So, it's time to RMA?
FFS
  • 5786
  • 525
« Reply #16 on: January 30, 2010, 12:27:36 pm »
Yes, sorry, I think it might need RMA as I am running out of ideas. It is really hard to solve these type of issues without being able to get hands on.
Pottypete
  • 686
  • 15
« Reply #17 on: January 30, 2010, 01:01:37 pm »
hi,
have you tried formatting your  hard drive in another computer?
It worked for other users on this forum,
Worth a shot!
Cheers
« Reply #18 on: January 30, 2010, 01:45:34 pm »
I can't format my main HD. Too much important Data.
I tried the Sata ports with another drive though. it didn't work.
Also, at start i thought it's the hard disk fault, but i since the dvd drive doesn't work either, it's something with the mobo.
