Resolution Toggle Bios z87x ud5h
« on: June 16, 2013, 10:54:38 am »
Has anyone been able to use the "Resolution Toggle" on a z87 board?
I get a pop up stating "sorry that full HD isn.t supported in current configuration"
MB.: Gigabyte Z370x Gaming 7 - Bios F5e
Proc.: Intel I5 - 8600k
Mem.: Corsair Dominator 3000mhz 2 x 8gb
Cpu.: Gelid the Black Edition.
Gpu.: Asus GTX 670.
Power.: NZXT 650 watt.
Ssd.: Samsung 850 Evo(256gb)
Hd.: WD 1 x 1 Tb Blue (Storage)
Hd.: WD 1 x 4 Tb Blue (Storage
Re: Resolution Toggle Bios z87x ud5h
« Reply #1 on: June 16, 2013, 11:16:27 am »
i have the same problem on z87x OC version , no mather bios ( tested on F3,F4,F5l)  :-\
I5 4670K (oc 4,5 Ghz 1.307 V )  , Gigabyte Z87X-OC  , Corsair Dominator GT  CMT8GX3M2B2133C9
SDD OCZ Vertex 3, 2x Seagate 250 GB (RAID 0)
« Reply #2 on: June 16, 2013, 11:23:26 am »
Clear, so we will have to wait till GB solves this in a future Bios update.
Gpu.: Asus GTX 670.
ysw
  • 152
« Reply #3 on: June 18, 2013, 04:08:13 am »
have u tried to use dvi port, not hdmi?
« Reply #4 on: June 18, 2013, 09:08:34 am »
My 560ti is connected from the dvi port.
Gpu.: Asus GTX 670.
Gloup_Gloup
  • 982
  • 33
« Reply #5 on: June 18, 2013, 01:07:02 pm »
Hi all,
Just said .... the last drivers for nVIDIA causes many problems...
Do not use a NVIDIA drivers 300.18
It is important do not install a last nVIDIA drivers.
Last drivers cause many problems ....
Keep drivers 314.22
About NVIDIA drivers:
I find infos...
http://www.nvidia.fr/object/win8-win7-winvista-64bit-314.22-whql-driver-fr.html
« Reply #6 on: June 18, 2013, 01:47:33 pm »
i'm using 311.06, just installed 314.22 no difference
« Last Edit: June 18, 2013, 02:09:08 pm by polypenko »
Gpu.: Asus GTX 670.
Gloup_Gloup
  • 982
  • 33
« Reply #7 on: June 18, 2013, 04:55:44 pm »
Have you tried HDMI port?
Have you a same problem with VGA port (D-sub)?
You use a OS Windows or Linux?
Have you make a Clear CMOS in past time?
If you want try...
how to clear cmos
http://forum.giga-byte.co.uk/index.php/topic,2286.0.html
« Last Edit: June 18, 2013, 05:06:06 pm by Gloup_Gloup »
« Reply #8 on: June 18, 2013, 05:41:14 pm »
just connected my monitor from my 560ti via hdmi / hdmi same problem.
Yes I have cleared the cmos after vrious bios updates.
Read somewhere else that it might work woth the int. graphic, but stand alone vk seem not yet to work.
Gpu.: Asus GTX 670.
Gloup_Gloup
  • 982
  • 33
« Reply #9 on: June 18, 2013, 06:41:46 pm »
Have you tried with Live Linux CD or DVD ?
Like Hirens.BootCD.15.2
« Last Edit: June 18, 2013, 06:42:45 pm by Gloup_Gloup »
« Reply #10 on: June 18, 2013, 07:01:02 pm »
I use windows pro 64 bits with a Gigabyte 560ti vK.
I'm not familiar with Linux.
Gpu.: Asus GTX 670.
ysw
  • 152
« Reply #11 on: June 19, 2013, 04:00:50 am »
you may check your graphics card if your card's vbios supports 1920x1080 full HD.
« Reply #12 on: June 19, 2013, 08:11:58 am »
supports up to 2560 x 1600, however monitor max 1920 x 1080
http://www.gigabyte.co.nl/products/product-page.aspx?pid=3707#sp
Gpu.: Asus GTX 670.
« Reply #13 on: June 20, 2013, 02:51:47 am »
some nvidia guys are checking this but not yet for a solution
there could be some update from them soon
christianh
« Reply #14 on: June 27, 2013, 01:38:58 am »
Doesn't work with my AMD HD6850 card either, says it's not supported. On my ud3h. My monitor does support 1920x1200 using dvi.
