BRIX - can I upgrade the processor?
M__K
« on: May 27, 2014, 01:38:10 pm »
RE: Gigabyte BRIX GB-BXCEH-2955 Barebone
Hi guys,
I'm thinking about buying the above BRIX with a celeron processor as I'm getting a good deal on it (I think).
Can I upgrade the processor later on as you would with a normal ATX Motherboard or is it soldered onto the board?
Thanks!
MK
Re: BRIX - can I upgrade the processor?
« Reply #1 on: May 27, 2014, 09:48:28 pm »
The CPU's are soldered to the motherboard. You won't be able to change the CPU later on. I'd avoid the Celeron unless you were getting it very very cheap.
It's a very slow CPU....but that model does offer room to install a laptop harddrive. (no room inside mine for one)
