ga-ma78gpm-ds2h
axemurderer
ga-ma78gpm-ds2h
« on: October 27, 2009, 03:16:22 pm »
ga-ma78gpm-ds2h with athlon250 and ocz2rpr11502gk @1066(1.95V).oc1150 easy(1.95V). Want to put 2 more dimms I think no 2 dimm limitation with AM3 cpu unless mb limitation.Will it work?If experience with this board anyone do comment.D9GMH axeram 800+ 4 dimms worked 2days @1066 even compatybiliti was poor with 2 dimms.2dimms DID NOT go 1066.Also any comments about this board are welcome.
axemurderer
Re: ga-ma78gpm-ds2h
« Reply #1 on: December 06, 2009, 07:14:48 pm »
waiting second kit arrivel.
kangoo
  • 127
Re: ga-ma78gpm-ds2h
« Reply #2 on: December 08, 2009, 07:08:55 am »
4 dimms will not work @1066 as it's written :
Due to AMD AM2+ CPU limitation, DDR2 1066 is only supported by 1 dimm per channel.
http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ma78gpm-ds2h.pdf
axemurderer
Re: ga-ma78gpm-ds2h
« Reply #3 on: February 27, 2010, 03:13:38 pm »
It´s alive!This means it works 4 dimms 1066.No problems so far. :)
axemurderer
Re: ga-ma78gpm-ds2h
« Reply #4 on: February 28, 2010, 05:31:22 pm »
Okay according AMD webpages performance benchmarks for athlonII and phenomII are done with four 2gig pc2 8500 dimms so sure it works.
