Gigabyte Z270-HD3P
Gigabyte Z270-HD3P
« on: April 21, 2017, 12:12:02 am »
Hi folks,
Recently DIY a desktop PC. I have enabled XMP to profile 1 in BIOs, and the memory frequency is showing the right 3200Mhz.
However, when I open Task Manager in Windows 10, under "Performance" tab, the memory speed is only displaying as 2133Mhz. Pardon me for my noob-ness, but how to configure further please? Is there any step missing?
Your kind advice will be greatly appreciated!
  • 2248
Re: Gigabyte Z270-HD3P
« Reply #1 on: April 21, 2017, 06:05:20 pm »
This is the base clock of your RAM.  Use App Center / SIV or CPU-Z if you want to see actual clock speed your memory is running at.
http://www.cpuid.com/softwares/cpu-z.html
« Reply #2 on: April 21, 2017, 11:50:15 pm »
Thanks bro for ur kind advice. I guess some mobos are just not so friendly with microsoft's Task Manager.
  • 2248
« Reply #3 on: April 22, 2017, 03:26:21 am »
Ya.  On the laptop I'm on now...  RAM speed does not appear in my Task Manager > Performance Tab > Memory.  On my Z97 desktop its there and both are running build 1607 of W10x64.
