GTX 980ti errors
MMax4
GTX 980ti errors
« on: April 15, 2016, 05:58:35 pm »
Hi there,
I just bought a new GTX 980ti Xtreme Gaming, and it soon seemed to be having problems. For the first few hours, it was working fine, but then it started blue screening. I have been using my computer for a while, and it never happened before this. I have tried reinstalling drivers and such, but it still continues. I have had a few games crash saying "GPU not responding". I tried taking out my memory and putting it back in. Any help would be appreciated!
NVidia driver version: 364.72
Windows 10
Intel I7-4790K
750w Corsair PSU
16GB Ballistx Sport Memory
MSI Z97 Gaming 5 Motherboard
Blue Screens:
Memory_Management
System_Service_exception
kmode_exception_not_handled
page_fault_in_nonpaged_area
« Last Edit: April 15, 2016, 06:01:45 pm by MMax4 »
Re: GTX 980ti errors
« Reply #1 on: July 08, 2016, 02:06:04 am »
This is going to be hard to pinpoint. My thoughts are
Run.extended memtest
Try driver 362.00 anything newer IMO is not good.
Under clock the GPU. This will tell you if it is a voltage issue. If I had to make one guess I bet this is the.cause, but you do have a good PSU. Try watching the voltages for.fluctuations.
Increase the voltage.to the GPU by 0.05. Perhaps the CPU/nb after that.
Just my guesses. I wish you luck.
