Gigabyte brix pro i7 not keeping time
« on: June 04, 2016, 08:42:49 am »
I've owned a gigabyte brix for over a year and since the day I have had it it never keeps time and date when switched off. Is there a way to check the cmos battery and also which one do I purchase if I need it replaced.
Running Windows 7 professional.
  • 3111
Re: Gigabyte brix pro i7 not keeping time
« Reply #1 on: June 04, 2016, 12:44:42 pm »
You should replace it and the battery does have a # on it. CR2032
« Reply #2 on: June 06, 2016, 08:29:38 am »
ok, Ive noticed that the cmos battery is atteched by a plug. Is there a specific one I should purchase. All the ones I see online are for HP, Acer, Dell etc. Will all of these fit the motherboard or is there a specific one I should purchase. Any help appreciated.
  • 3111
« Reply #3 on: June 06, 2016, 01:30:17 pm »
You can buy them almost any where. What country are you in? One other thing what motherboard do you have?
« Reply #4 on: June 06, 2016, 10:22:37 pm »
I live in the UK. I'm I have a 4770r.
