Z170X Gaming 7 boot image
« on: July 05, 2016, 03:05:47 pm »
Hello guys
i just upgraded to the Z170X Gaming 7 motherboard with a 6700k and i was wondering if there is a way to add a custom boot image
Has anyone tested it on the Z170X Gaming 7 motherboard?
  • 2243
Re: Z170X Gaming 7 boot image
« Reply #1 on: July 05, 2016, 07:09:40 pm »
Hello guys
What is your definition of a custom boot image?  Can you tell us what you're trying to do/desired outcome?
« Reply #2 on: July 05, 2016, 08:22:43 pm »
Hello guys
This is the default BIOS boot image, i want to replace it with a custom image
  • 3078
« Reply #3 on: July 05, 2016, 10:20:01 pm »
What OS you running. If it is windows 10 that shouldn't last but a few seconds. I know everybody has their own thing. But I get a kick out how people want to change bios screens that only a few seconds.
https://www.google.com/#q=custom+bios+screens
  • 2243
« Reply #4 on: July 06, 2016, 12:26:14 am »
I would do a lot or research before doing this. Have a look at this.
http://www.intowindows.com/facewizard-personalize-gigabyte-motherboard-boot-up-logo/
