1060 received from amazon in unsealed box?
« on: November 13, 2016, 10:09:03 pm »
Is it standard practice for Gigabyte to send out items without their own Gigabyte seal on the box?  Last time I bought from gigabyte(3 years ago) it had a Gigabyte seal.
While I'm here, there was no warranty/guarantee card in the box.  I take it the amazon invoice is my guarantee?
Thanks in advance.
  • 2246
Re: 1060 received from amazon in unsealed box?
« Reply #1 on: November 14, 2016, 03:03:32 am »
Welcome to the forums.
While its not your fault you received a product that had been opened...  Its not Gigabytes fault either.
My advice, contact Amazon.  They sold you the "open" box.
« Last Edit: November 14, 2016, 03:04:51 am by shadowsports »
« Reply #2 on: November 14, 2016, 12:25:28 pm »
First, thanks for the welcome.
Second, I wasn't trying to aim blame at anyone.  I was asking if it was common practice, by Gigabyte, to not seal boxes.
I take it from your response that it should have been sealed?
Already been in touch with Amazon, who's response was less than helpful.  I was just trying to find out from here if anyone else has had packaging from Gigabyte unsealed.
« Reply #3 on: November 14, 2016, 02:43:16 pm »
From my own experiences, having purchased Gigabyte motherboards and GPU's, usually the outer box is not sealed nor does it usually have a cellophane wrapping.
The motherboard/GPU has, however, been wrapped inside a sealed anti-static bag, inside the box.
  • 2246
« Reply #4 on: November 14, 2016, 06:53:22 pm »
To second what absic has said.  My only experience is with gigabyte MB's.  Only the static bag is sealed.  Box can be opened freely.  I don't know about GPU's...  only buy/use EVGA...  and they come with a seal that has to be broken to open the box.  Take a close look at the gold plating where the card gets inserted into the PCIe slot.  You should be able to tell if the card has been installed previously.
AgentFXA
  • 379
  • 17
    • none
« Reply #5 on: November 22, 2016, 01:17:19 am »
Probably depends on the country's consumer laws...
here in Australia in general nothing (electronics) is packed in a sealed condition
Same for all Gigabyte products hence you never know when a shop sells on returned products (which is very common in this country.)
« Last Edit: November 22, 2016, 01:18:36 am by AgentFXA »
X570 Aorus Elite Wifi / Ryzen 2700x / Gigabyte Radeon RX 7900 XT Gaming OC 20G Graphics Card / 16 GB HyperX Predator 3200 / SeaSonic 850W / Tt View 71 TG / Win10x64
reeven
  • 40
« Reply #6 on: November 22, 2016, 12:27:27 pm »
dont worry. enjoy for videocard.
mine from states also came without sealed stamp.
Gigabyte series 1060 are top noch.
