970A-UD3P rev1.0 — GNU/Linux issues
b1s
« on: June 21, 2017, 11:35:07 am »
Hello everyone!
I'd like to start off by saying Windows works fine so my issue is not hardware fault related. So my motherboard (970A-UD3P rev1.0) won't let me install any Linux distro. I've literally tried at least 5 different distros (Ubuntu, Arch, Solus, Fedora, Debian, Antergos, Manjaro, etc.) and all of the had the same hanging issues. By hanging I mean the computer hard freezes after a few minutes of use and I need to reset the whole system.
My setup consists of a FX-6300 (running at default clock speed), a GTX 660 and four gigs of kingston memory.
Has anyone suffered/is suffering from the same issues? If so, have you found a resolution? Thank you in advance!
« Last Edit: June 21, 2017, 11:44:35 am by b1s »
b1s
Re: 970A-UD3P rev1.0 — GNU/Linux issues
« Reply #1 on: August 14, 2017, 07:58:25 pm »
Aaaaaand this is why I'm never going to buy a gigabyte product again. f*** you, gigabyte.
« Reply #2 on: August 15, 2017, 11:05:37 am »
Hello,
Maybe a Kernel issue, a lot of the VIA USB controllers don't work well.
Try disabling the VIA USB controller.
The hang, if you were to have a video playing from YouTube does it stop or continue?
My PC is evolving
b1s
« Reply #3 on: August 15, 2017, 12:03:55 pm »
How do I disable the VIA USB controller?
And yes, I found that if I have a video playing from youtube, the hang happens sooner.
« Reply #4 on: August 15, 2017, 01:53:39 pm »
In your BIOS look under the peripherals section.
USB3.0 Controller (VIA® VL805 USB Controller) = Disabled.
Note when you do this all the USB3.0 ports will stop working but for testing purposes give it a go.
Do you also happen to use a AIO water cooler?
Some of these require software to control the pump, eg, NZXT Kraken X62.
With another PC I have it can over heat in any Linux OS as the Pump is not being controlled.
My PC is evolving
b1s
« Reply #5 on: August 15, 2017, 06:17:59 pm »
No, I use the stock coolers.
