AppCenter B15.0916.1 self-update InstUPD fails with .NET runtime error
AppCenter wants to update itself, but the update always fails.
I have tried downloading a new version from the Gigabyte website, but the package is dated 2014, so that's no good.
Here are the errors in EventVWR:
Code: [Select]
Faulting application name: InstUpd.exe, version: 1.0.0.0, time stamp: 0x59802542
Faulting module name: KERNELBASE.dll, version: 10.0.15063.502, time stamp: 0xc3955624
Exception code: 0xe0434352
Fault offset: 0x000eb802
Faulting process ID: 0x2a24
Faulting application start time: 0x01d320b73f3bac32
Faulting application path: C:\Users\jonski\AppData\Local\Temp\7zS9219.tmp\AppCenter\InstUpd.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report ID: baa9bf10-e101-4da1-b46f-b167223c6ab7
Faulting package full name:
Faulting package-relative application ID:
.NET runtime error
Code: [Select]
Application: InstUpd.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
   at InstUpd.MainWindow.ReadInstalledVer()
   at InstUpd.MainWindow..ctor()
Exception Info: System.Reflection.TargetInvocationException
   at System.RuntimeTypeHandle.CreateInstance(System.RuntimeType, Boolean, Boolean, Boolean ByRef, System.RuntimeMethodHandleInternal ByRef, Boolean ByRef)
   at System.RuntimeType.CreateInstanceSlow(Boolean, Boolean, Boolean, System.Threading.StackCrawlMark ByRef)
   at System.RuntimeType.CreateInstanceDefaultCtor(Boolean, Boolean, Boolean, System.Threading.StackCrawlMark ByRef)
   at System.Activator.CreateInstance(System.Type, Boolean)
   at System.RuntimeType.CreateInstanceImpl(System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo, System.Object[], System.Threading.StackCrawlMark ByRef)
   at System.Activator.CreateInstance(System.Type, System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo, System.Object[])
   at System.Activator.CreateInstance(System.Type, System.Object[])
   at System.Xaml.Schema.SafeReflectionInvoker.CreateInstanceCritical(System.Type, System.Object[])
   at System.Xaml.Schema.SafeReflectionInvoker.CreateInstance(System.Type, System.Object[])
   at System.Xaml.Schema.XamlTypeInvoker.CreateInstance(System.Object[])
   at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstanceWithCtor(System.Xaml.XamlType, System.Object[])
   at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstance(System.Xaml.XamlType, System.Object[])
   at System.Xaml.XamlObjectWriter.Logic_CreateAndAssignToParentStart(MS.Internal.Xaml.Context.ObjectWriterContext)
   at System.Xaml.XamlObjectWriter.WriteStartMember(System.Xaml.XamlMember)
   at System.Xaml.XamlWriter.WriteNode(System.Xaml.XamlReader)
   at System.Windows.Markup.WpfXamlLoader.TransformNodes(System.Xaml.XamlReader, System.Xaml.XamlObjectWriter, Boolean, Boolean, Boolean, System.Xaml.IXamlLineInfo, System.Xaml.IXamlLineInfoConsumer, MS.Internal.Xaml.Context.XamlContextStack`1<System.Windows.Markup.WpfXamlFrame>, System.Windows.Markup.IStyleConnector)
   at System.Windows.Markup.WpfXamlLoader.Load(System.Xaml.XamlReader, System.Xaml.IXamlObjectWriterFactory, Boolean, System.Object, System.Xaml.XamlObjectWriterSettings, System.Uri)
   at System.Windows.Markup.WpfXamlLoader.LoadBaml(System.Xaml.XamlReader, Boolean, System.Object, System.Xaml.Permissions.XamlAccessLevel, System.Uri)
   at System.Windows.Markup.XamlReader.LoadBaml(System.IO.Stream, System.Windows.Markup.ParserContext, System.Object, Boolean)
   at System.Windows.Application.LoadBamlStreamWithSyncInfo(System.IO.Stream, System.Windows.Markup.ParserContext)
   at System.Windows.Application.LoadComponent(System.Uri, Boolean)
   at System.Windows.Application.DoStartup()
   at System.Windows.Application.<.ctor>b__1_0(System.Object)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object)
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
   at System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame)
   at System.Windows.Application.RunDispatcher(System.Object)
   at System.Windows.Application.RunInternal(System.Windows.Window)
   at System.Windows.Application.Run(System.Windows.Window)
   at InstUpd.App.Main()
  • 2256
Re: AppCenter B15.0916.1 self-update InstUPD fails with .NET runtime error
« Reply #1 on: November 13, 2017, 03:22:59 pm »
Old thread, but to resolve, I would suggest uninstalling any app center components, then App Center itself, restart and attempt to install the latest version available for your board.  If this fails, you can troubleshoot why it won't install in your software environment.  Start with does the user account you are installing under have admin permissions.
Also helpful if you provide your hardware specs (board model at the very least) and the OS you are running.
