Z270x Gaming 7 Fan software no longer working after update!
Hosney
« on: September 18, 2017, 08:12:08 am »
I receaved a notification from the app center to update the easy tune utelity ,so I updated it ,but after the update the fan controlling software is no longer working under windows, I can adjust the fan speeds via the bios only.
is there a solution?
Re: Z270x Gaming 7 Fan software no longer working after update!
« Reply #1 on: September 20, 2017, 04:20:49 pm »
ihad the same prob my fan software and lighting  software stoped working and even then in the bios it wouldnt change or work  i uninstaled all <  gigabyte  software it bakes your system most of the time and uses alot of resoruces  imo. i would just use your bios for evything man  im on z270 gamin k5 latest bios
