GA-970A-DS3P rev. 2 - half of memory is "hardware reserverd" in Windows 10
Lotto
Windows 10 x64 on my PC sees 16 Gb of RAM but shows the half of is as "Hardware Reserved". Only 8 Gb can be used. Does someone has an idea why?
* GA-970A-DS3P rev 2. BIOS rev. FD (the newest existing version)
* CPU AMD FX-8300
* 2 x 8 Gb memory sticks (Kingston KXH1866C10D3 / DDR3-1866 / PC3-14900 DDR3 SDRAM UDIMM)
* PCI-E NVidia GeForce GTX 950
* No overclocking, all settings in BIOS set to Auto.
BIOS shows both the modules, and they both are recognized by HWInfo64.
I rummaged through BIOS settings and didn't find anything that could fix the situation. What's strange, the only working memory stick combination is same-colored slots 1&2. Any other combination of memory sticks and RAM slots on the MB - and the computer simply doesn't turn on. And what's even more strange, I can't turn on the system with only one memory stick installed in any slot.
Looks pretty similar to RAM hot-swap systems with one RAM module in standby, except this feature was never implemented in PC-class motherboards. A dual-channel bug?
  • 2259
This is more challenging to solve.  Older board 5+ years only now.  1866Mhz RAM is a little obscure.
Part number doesn't even come up when I search on Kingston's site.
You can try setting memory timing, voltage parameters manually and see if that works.
