M.2 on Old X58a UDR3 rev 1.0
Graceman
  • 200
« on: January 21, 2021, 01:58:38 pm »
I Lost my old hard drive so need replacement, intrigued with the option to fit PCIE Riser card and a M.2 Board using the samsung or western digital device .
Will it take the new config . ?
MB is GA X58A Udr3 rev 1.0 Yes its old but functional and really runs quite fast.
Or do I play safe and just plug in new HDD.
Antec NSK4000B II Midi Tower Case
Gigabyte G1 Sniper M3 rv 1.0
I7/3770K
16Gb Csair Vengance Ram
Corsair CMPSU-430CXV2UK PSU  CX430V2
OCZ RVD3-FHPX4-240G 240GB RevoDrive3 PCI-E SSD
Alcool DC-LT 12v Ceramic Pump
Alcool Rvoir for DC-LT Pump
Alcool DC-LT Pump Top
EK Supremacy CSQ Univ Full
  • 2263
Re: M.2 on Old X58a UDR3 rev 1.0
« Reply #1 on: January 22, 2021, 02:47:22 pm »
Play it safe and use a standard SSD.
  • 3112
« Reply #2 on: January 22, 2021, 07:46:08 pm »
My Plextor AGT-512B1p PCXe-1 card works fine in my ancient 1366 Asus P6T. The board is like 11 or 12 yrs old. LOL
Just make sure you put a card for M.2 SSD's goes into a PCXe slot and not one of the small ones.
https://picclick.co.uk/Plextor-bridge-card-PCIe-to-NVMe-AGT-512B1P-used-224217818308.html
« Last Edit: January 22, 2021, 08:03:18 pm by dmdilks »
  • 3112
« Reply #3 on: January 23, 2021, 12:45:09 am »
Plus the card does support NVMe SSD's. Just tested it on my Old Asus P6T. Got into windows there it was in This PC.
Graceman
  • 200
« Reply #4 on: January 24, 2021, 01:33:30 pm »
I Note Shadow spots reply and would normally agree but for £58 plus £6 fro riser card its seems a reasonable solution.
Might just try it ?
I7/3770K
  • 2263
« Reply #5 on: January 24, 2021, 02:04:14 pm »
I Note Shadow spots reply and would normally agree but for £58 plus £6 for riser card its seems a reasonable solution.
Might just try it ?
I'm not saying it can't be done, only that I wouldn't invest time or money in (x58) 12 yr old technology.
Graceman
  • 200
« Reply #6 on: January 25, 2021, 05:27:43 pm »
After reading further decided to stick with WD Blue Caviar 500 GB standard Hdd for £39
There was a suspected issue that the Bios would not recognise it.
Although an old card it does the job slightly overclocked.
Ideal for the internet use I need.
I7/3770K
