AMD - Gigabyte Boards That Will Pass TPM 2.0 Verification Without a TPM Chip
  • 2258
In case you missed it.  This article claims the following boards will support Windows 11 TPM 2.0 Verification through an upgraded BIOS without a TPM chip.
AMD TRX40, 300, 400, 500 motherboards are TPM 2.0 function ready, which can pass the upgraded Windows 11 OS verification.
https://www.gigabyte.com/Press/News/1925
There are going to be minimum CPU requirements as well.
https://docs.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-amd-processors
Hopefully Microsoft allows this to work.
