Motherboards with HDCP support
« on: September 19, 2021, 07:29:20 pm »
Which Gigabyte motherboards support HDCP?
I'd like to build a Windows 10 HTPC with Intel processor that supports HDCP.
I am currently using a GA-Z170X-Gaming 7 motherboard with an Intel i5 processor that does support HDCP.  But I purchased it prior to Windows 10 availability.  Unfortunately, the board does not fully support Windows 10 audio and video drivers.
Thank you!!
  • 2259
Re: Motherboards with HDCP support
« Reply #1 on: September 21, 2021, 05:35:03 am »
I don't know if there is a list with this specific information.
You may want to contact sales/support.  They might be able to provide a list.  You may need to specify a platform (chipset, CPU, etc).
HDCP also requires a compliant cable and display.
