rgb Fusion 2.0 not detecting my Auros rx 6800 xt master with lcd edge view
Im getting really desperate, rgb fusion 2.0 has stopped recognising my gpu . ive tried all sorts of things and nothing working, can anyone recommend anything i could try/do to solve the issue.
things ive tried;
Uninstalled using revo uninstaller, Reinstalled and ran software as administrator.
moved the Atitool file to the desktop.
Downloaded earlier versions of the software; detected my ram???? corsair vengeance rgb.
Deleted all other rgb software like icue and signal rgb.
pretty much everything except a complete system reboot.
  • 2237
Im getting really desperate...
Did you mean everything except reinstalling windows?  If you haven't restarted your system after the other changes made above, you should give that a try.
Since you said stopped recognizing, what changed?
Did you upgrade Aorus Engine, RGB Fusion or App Center, etc?
This list might be out of date, but I don't see your card listed as being supported.
https://www.gigabyte.com/MicroSite/512/support.html
Other options:
What about System Restore?
Do you have a back up solution implemented?  Both are a great ways to test compatibility and functionality after a software or application update/change.
« Last Edit: January 24, 2022, 02:25:44 pm by shadowsports »
