« Reply #1 on: January 13, 2022, 03:45:54 pm »
I'm trying to fix a friends PC
When the power button is pressed nothing occurs. No fans start no leds go on. There is no boot not even into bios.
I have confirmed that the PSU is working, as is the RAM and the SSD drive with windows 10 on it.
The motherboard is quite old and i am wondering if someone can tell me if there is on option on the motherboard to jump start the PC directly without using the mechanical power button. The Motherboard is a Gigabyte P67A-UD3-B3
Any help appreciated
Erick
if you are referring to the power button on the case, its connected to a 2 pin motherboard header on the board. Its possible to short these PINs using a small screwdriver or similar.
« Last Edit: January 13, 2022, 03:46:48 pm by shadowsports »
Logged
Z390 AORUS PRO (F10) \850w, 9900K, 32GB GSkill TriZ RGB - 16-18-18-38, RTX 3080Ti FTW3 Ultra, 960 Pro_m.2, W10 21H2
Z370-HD3P (F5) \750w, 8350K, 8GB LPX 3200 - 16-18-18-38, GTX 970 FTW SC, Intel SSD, 2TB RAID1, W10 21H2
