i5 8400 CPU
i5 8400 CPU
« on: April 23, 2022, 08:03:45 am »
Apologies for 'basic' question but I would like confirmation before buying something (cpu).  I have a gigabyte Z390 UD (not sure which rev) motherboard that I intend to put in a i5 8400 cpu that has onboard graphics.  Is it as simple as inserting the cpu and a graphics output will be available from the rear hdmi port? (My monitor only has vga i/p so I will have to also buy a hdmi/vga adapter.  I am a non gamer so not worried about loss of hdmi quality).
  • 2258
Re: i5 8400 CPU
« Reply #1 on: April 24, 2022, 02:30:35 pm »
Yes.  As easy as that.
Here are the GPU specs for an i5 8500
Processor Graphics
Processor Graphics ‡
Intel® UHD Graphics 630
Graphics Base Frequency
350 MHz
Graphics Max Dynamic Frequency
1.05 GHz
Graphics Video Max Memory
64 GB
4K Support
Yes, at 60Hz
Max Resolution (HDMI)‡
4096x2304@24Hz
Max Resolution (DP)‡
4096x2304@60Hz
Max Resolution (eDP - Integrated Flat Panel)‡
4096x2304@60Hz
DirectX* Support
12
OpenGL* Support
4.5
Intel® Quick Sync Video
Yes
Intel® InTru™ 3D Technology
Yes
Intel® Clear Video HD Technology
Yes
Intel® Clear Video Technology
Yes
# of Displays Supported ‡
3
  • 2258
Re: i5 8400 CPU
« Reply #2 on: April 25, 2022, 02:11:48 am »
Sorry typo - meant i5 8400
