« Reply #1 on: May 03, 2022, 12:22:27 am »
I am a fan of PrecisionX1 also. It's by far one of the most comprehensive, stable apps made. I use EVGA exclusively for this reason. (Primarily drivers). No nonsense warranty too.
Admittedly, I have not used Aorus Engine, but Gigabyte cards would be my second choice. Design is awesome and the vortex fan thing is also cool (literally).
But let's talk about what you aren't getting from Aorus Engine. What card do you have? What case are you running it with and what type of cooling? Are you OC'ing (pushing) your card for maximum FPS? Are you overheating? I find that many people attempt to use software and custom fan curves to make up for poor case choice or inadequate cooling.
Providing some examples or greater details might help. Here is a good blog on AE:
https://www.blogsdna.com/36145/what-is-aorus-engine.htm#How_to_Use_Aorus_Engine Also a tutorial:
https://youtu.be/6eEEh8b0StA
« Last Edit: May 03, 2022, 12:38:17 am by shadowsports »
Logged
Z390 AORUS PRO (F10) \850w, 9900K, 32GB GSkill TriZ RGB - 16-18-18-38, RTX 3080Ti FTW3 Ultra, 960 Pro_m.2, W10 21H2
Z370-HD3P (F5) \750w, 8350K, 8GB LPX 3200 - 16-18-18-38, GTX 970 FTW SC, Intel SSD, 2TB RAID1, W10 21H2
