Login
Register
Close
Login
Remember me
Toggle navigation
Home
Help
Login
Register
Questions about GIGABYTE products
Motherboards with AMD processors
AMD A520 Motherboards
« previous
next »
Print
Pages: [
1
Go Down
teknology9
716
32
on:
April 07, 2023, 07:46:06 pm »
Hi all,
I am aware that there were some issues with AMD B550 and X570 boards concerning USB connectivity, is the issue likely to affect the A520 boards or has a bios update solved the problem?
Thanks,
Teknology9
Logged
Windows 11Home Edition
NZXT Phantom
Seasonic Platinum 1000w
Noctua NH-U12P SE2
Corsair 16GB 3200
Gigabyte B550 Aorus Elite V2 Rev 1.5
MSI GeForce GTX 1650 D6 Gaming X 4G
Ryzen 5 5600
Samsung 970 Evo Plus - 250GB
Samsung 830 SSD - 250GB
PC building.........it's no fun if it's easy!!!
teknology9
716
32
Re: AMD A520 Motherboards
Reply #1 on:
April 22, 2023, 12:34:27 pm »
It appears that a BIOS version has addressed the issue, my MB shipped with version 15 so should be fine.
teknology9
Logged
NZXT Phantom
Noctua NH-U12P SE2
Corsair 16GB 3200
Ryzen 5 5600
2264
67
Xbox One, Drives STI, Use QVL RAM For Best Results
Reply #2 on:
April 28, 2023, 03:42:48 pm »
Helpful info for others.
Logged
Z390 AORUS PRO (F10)
\850w, 9900K, 32GB GSkill TriZ RGB - 16-18-18-38, RTX 3080Ti FTW3 Ultra, 960 Pro_m.2, W11
teknology9
716
32
Reply #3 on:
May 01, 2023, 06:03:41 pm »
I also had a reply from Gigabyte eSupport and they recommended not updating the BIOS unless it was necessary. Therefore, if it is not broken don't try and fix it.
Cheers,
teknology9
Logged
NZXT Phantom
Noctua NH-U12P SE2
Corsair 16GB 3200
Ryzen 5 5600
3121
43
"If it isn't broke don't fix it"
Reply #4 on:
May 07, 2023, 03:51:31 pm »
I have a A520M DS3H and the USB's work, but the mouse some times doesn't work right. Plus I have the F15 bios on it too. I can connect that mouse to another computer and have issues at all with it. I have had many different issues with this board.
I had a Gigabyte 1070 8gb card that was giving me white screen when gaming. Even did some bsod too. Swap it out with another PNY 1070 8gb no issues. Put the Gigabyte 1070 into another computer no issues.
One thing at one time I was AMD junkie. Today I will not own a AMD computer for myself. I have 10 times more problems with AMD vs Intel.
Logged
Print
Pages: [
1
Go Up
« previous
next »
