X470 AORUS GAMING 7 WIFI bios f63d post code 33
y0rge
« on: May 03, 2023, 01:00:23 pm »
Hello i have done bios update in order to swap my cpu from 2700x to 5800x3d
Before bios update mb post code show 24 almost all the time
On f40 bios update it show AA ( i look on web and people say is ok)
On bios f63d it show 33. From mb manual post code, it say : 32~36 CPU PEI initialization.
Pc work fine  there is no problem, ram profile loaded no problems atm.
My q for more advanced users Should i be worry abut this post code ? or it is fine and i can move to buy new cpu ?
TY for any help
Re: X470 AORUS GAMING 7 WIFI bios f63d post code 33
« Reply #1 on: September 28, 2023, 05:45:05 pm »
Late reply.  For this issue, I would remove and inspect the bottom of the CPU for bent pins.  You can use a credit card to straighten if needed.  Next inspect the socket on the MB for anything that looks abnormal.  Of all looks ok, reseat, re-apply thermal compound and retest.
