Z590 D and second monitor output
fonon
  • 16
« on: August 19, 2023, 06:58:34 am »
Is it possible to connect a second monitor to the motherboard via internal thunderbolt connector without a dedicated expansion card? If yes - how?
Re: Z590 D and second monitor output
« Reply #1 on: September 28, 2023, 05:28:58 pm »
No.  The board has a single display port.  Only one display is supported.
fonon
  • 16
« Reply #2 on: October 07, 2023, 10:04:46 pm »
And what's about thunderbolt connector?
« Reply #3 on: October 08, 2023, 12:45:50 am »
My apologies, I wasn't clear on your question.  The internal header allows you to connect a Thunderbolt card.
Gigabyte makes 5 different models.
https://www.gigabyte.com/us/Motherboard/Thunderbolt-Card
The one for your board is the MapleRidge.  It has to be installed to the x4 slot.  You can read about it here:
https://www.gigabyte.com/us/Motherboard/GC-MAPLE-RIDGE-rev-10#kf
However, you cannot connect a display to the internal header, you must install a card.
