Gigabyte motherboard not starting up properly
hakbul
« on: October 16, 2023, 01:24:07 pm »
I have Gigabyte motherboard Z390 UD V2, the only happening when trying to power up pc is Case fans spinning 1 lap.
after about 30 secs rgb memory sticks light up. Nothing more happens.
I have tried different memory, different casing. No change.
Havent change cpu or Psu though. But cpu pins look ok.
Any idea what can be wrong here?
Best regards
Hakan
Re: Gigabyte motherboard not starting up properly
« Reply #1 on: October 17, 2023, 02:41:43 pm »
Best regards
Hakan
Some questions for you.
Please provide your full system specs, including disks, PSU, etc.  What's installed, attached and where, etc.
What CPU are you using (specifically)?
What Memory (Brand, model, spec)? you said you tried more than one kind??
What BIOS rev are you running?
Have you tried Clearing the CMOS [CLR_CMOS]?
Have you seen any error LEDs? (Lower right corner) CPU, VGA, DRAM, BOOT
"1 lap"???  What does this mean exactly?
Manual:
https://download.gigabyte.com/FileList/Manual/mb_manual_z390-ud-v2_e.pdf?v=d0c0d71f3deeb06229e5c709825da79a
« Last Edit: October 17, 2023, 02:44:00 pm by shadowsports »
