Z790 UD - where's the MCE (multi-core enhancement) setting in BIOS?
XLR
  • 14
Is it possible to disable MCE and set P1/P2 power limits to match Intel's official specs for 13900K, instead of unlimited?
Can't find any of those settings in two latest BIOS versions... Maybe they appear under different names?
Re: Z790 UD - where's the MCE (multi-core enhancement) setting in BIOS?
« Reply #1 on: November 13, 2023, 03:16:42 pm »
Check under the Tweaker Menu.
