Mobo Z690 UD - Is the M2X3mm screw suitable for an M2 NVME PCI HD?
maldon
Hi. Noob question.
I bought a third M.2 NVME PCI HD (xpg s70 blade) to install in the MOBO. However, I didn't find the screw to lock the HD. I'm buying it but some doubts arose because it seems like there is more than one type.
Would M2X3mm be the right one to use on this card in relation to a PCIe 4 NVMe HD?
The motherboard already comes with the screw support (as shown in the attached photo).
Thanks.
  • 2237
Re: Mobo Z690 UD - Is the M2X3mm screw suitable for an M2 NVME PCI HD?
« Reply #1 on: November 23, 2023, 04:51:12 am »
M2x3 or 4mm should work
« Last Edit: November 23, 2023, 04:52:27 am by shadowsports »
