Problem with "waking up" H110M-S2H board.
amron
  • 24
« on: December 02, 2023, 09:00:50 am »
I have a desktop with a H110M-S2H board and a SSD. Os is win10. When the pc is without use it goes into “sleep” mode. The problem is that when I wake it up, it starts to open the background picture, but it’s darker than the usual picture and then the display turns into totally black. The only solution is to turn it off and restart it and then it comes on normally. Any  ideas? Is it a hardware problem? In this case what would you suggest to check, or a problem with the Windows10?
  • 2256
Re: Problem with "waking up" H110M-S2H board.
« Reply #1 on: December 06, 2023, 03:17:59 pm »
What BIOS rev and processor are you running?
Are you using onboard graphics or a dedicated GPU?  (What brand/model)?
What display (brand/model/size, and what's it connected to?
Are you using any adapters?
Have you performed a CMOS Reset?  Does the behavior persist?
amron
  • 24
« Reply #2 on: December 14, 2023, 11:39:21 am »
The bios version is F25, the cpu is G4400.
Onboard graphics.
The display is Samsung SyncMaster 203B.
No additional adapters.
No, haven't done CMOS reset.
The situation now is that after the sleep mode, I have to restart the pc three! times. on the first attempt the display is a bit dimm and sort of flashing, on the second attempt the display is totaly dark and on the third time it's coming up normally.
  • 2256
« Reply #3 on: December 20, 2023, 03:01:26 pm »
Test with a different monitor cable.  If the behavior is the same, I'd perform a CMOS reset.
If the issue follows, you can try another chipset and display driver.  If none of these things help, its the CPU or motherboard.
